Originally Posted by BRAN
An illuminated Alu Boxster Logo in the little batwing.
I used a key chain Alu logo, which came with the back then brand new Boxster, stuck it into a milky plastic frame, used amber/yellow leds from an illuminated stick shifter to put them behind it and used the ashtray led Powerline to connect them with.
The picture is very roughly photoshoped to give you an idea, how it looks illuminated. I am sure, you could come up with a TOP Quality solution for that...or maybe even better ideas.
Cool idea Bran! Adding or modifying the car's interior lighting is not the easiest task :/ Trying to keep a factory look to the car is by all means the most challenging part
While in the context of interior lighting... here goes some other glow-in-the-dark Top Secret project I've been working on. Simply meant to modernize the look & feel of the Porsche gauges... which in my opinion are a tad boring in their stock format. Design is simple, it's a copy of the common AL gauge bezels concept you find everywhere but custom made to accommodate micro LEDs. Also requires a custom made PCB that sit behind a diffuser made out of PC (frosty finish). All of that hardware squeeze inside the bezel, and sits on top of the gauge's face. All it does is glow on the face of the gauges.
I've put up the idea with the local Pcar community here and got pretty good feedback. Some also recommended adding Sequencial Shift Lights (SSLs) around the tach's bezel (top). Concept: microcomputer taps onto the RPM pins from the OBD harness, interpret that signal, lights up LEDs according to the rpm range!
Perfect useless gadget for the little Ricer in us
However I must say the gauge glow thing is phenomenally beautiful... having seen a prototype working already (in red, of course).
Perhaps in 2015 I'll get back to this work - we'll see. I want my WIND DEFLECTOR before
