Old 11-20-2014, 12:55 PM   #3
TheSavyNeal
Originally Posted by jeffL View Post
I used PIONEER TS-A1675R 3-WAY easy fit and sound great.
no mods needed, just remove door panel, unscrew old and install new.
same screw holes. if you are hooked to factory amp you will get bass only.
if no amp or a custom amp you will get full range sound.
Right, looking to get something that has better bass response than factory without changing out anything else since it's not really going to increase the value.
If you're running off the amp why did you install a coaxial?
TheSavyNeal is offline   Reply With Quote
