Old 11-19-2014, 06:12 PM   #10
97-986
Looks like at some point in the past, someone removed and re-installed the oil sump plate with a generous bead of sealant. I believe it has been this way for the last 60,000 miles or more, since my service records go back that far and I don't see the oil sump pan cover being removed, and any of the past services that I have a record of wouldn't require it.
I'm glad I didn't wait to put in my EBS baffle (I almost postponed it to my next oil change)
I should talk a picture of the little pile of snakes in there, some over 2 inches long and hanging way through the oil pickup screen. I took off the pickup so I could make sure I got them all out. I should take a picture of the pile... Also a few small pieces of plastic in the screen.
Edit: now I am suddenly worried about the pieces that may have broken off and gone into the engine... I have never seen any pieces on the 2 oil filters I have cut apart (and I have not yet cut and spread out the filter from this change) but all of the little snake pieces look "intact" and not broken off. They are very strong...
The sump cover itself was very clean.
Now to scrape off all the sealant off the mating surfaces...
Steve
Hi Steve -
I know it's been a while since this post but I'm getting ready to pull my sump and I was wondering, does the pickup actually rest on or contact the sump pan when installed in car allowing oil to only pass through the channels before getting to the screen?
Thanks.
97-986 is offline   Reply With Quote
