Old 11-12-2014, 06:32 AM   #1
discodavieuk
Help! Door inside microswitch
Hi Guys,
Having a bit of a panic here.. I took my door panel off to fit LED lights to the outer door handle which light up with interior lights. It means when i unlock the car using the remote the leds light up under the door handle (see attached photo).
Everything went great except I have done something to the inside door handle microswitch.
When i pull the door handle from the inside the window doesn't drop. Otherwise the door and window work fine. I have searched high and low for a guide to replacing the INSIDE microswitch on the door handle but have had no luck. I am praying I have simply disconnected the switch by accident.
Has anyone replaced this switch? Is there a wire which plugs into the handle? I have had a look online and i cannot see where it plugs into the handle..
I'm having a slight panic attack here!
Any help would be appreciated
David
discodavieuk is offline   Reply With Quote
