Old 11-11-2014, 08:22 AM   #1
thstone
Needs a visual inspection of the WP with belt off. Any wobble or play in it at all? Any sign of water lines around the pump?
Pressure test cooling. The reservoir may be cracked.
Old cap would leave trunk moisture but not a puddle like you describe unless it was half screwed on.
If pump failed however, then boil over into the trunk would be next.
+1 ^^^ what Tim said ^^
