Old 04-04-2006, 10:11 AM   #5
deliriousga
deliriousga's Avatar
Go with the simple things like Randall and PerfectLap said. Check the parking brake then fuse(s) then the relay before going to the big stuff. If you pull your relay and put it back in and it still does not work, see if you can find someone nearby with a Boxster who will let you swap the relays to test before you buy a new one.
Good luck!
1966 Wife White/Brown Top
