Old 10-21-2014, 10:10 AM   #1
jsceash
jsceash's Avatar
OK you said you replaced the immobilizer. Did you get a key fob (the plastic part the key blade goes into) with the immobilizer and the ECU from the same car. Generally you can purchase all 3 from the same car which should be the same model and year as your car. In your case a 2003 or 2004 Boxster S with an automatic transmission would be the best match.
