Old 10-21-2014, 06:11 AM   #1
mgfranz
Thanks JFP, you are correct, that should have read Durametric not DME. And I did post the wrong readout for P1133, it should have been "Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Below Limit". But what could be the problem? I did recently, about 400 miles ago have to replace the fuel pump which failed, Bosch replacement...
mgfranz is offline   Reply With Quote
