Old 10-15-2014, 06:46 PM   #18
Ben006
Ben-Auto-Design
Ben006's Avatar
the first arm rest is done !
the door card is very easy to remove ! if there were no air bag that is one part that I would make in carbon, with a pull handle to open the door (I will think about that !)
The arm rest is easier to do than the handle suround, and I improve my technique each time !
I'm also working on an improved version of the cheap short shifter you find on ebay ! There will be absolutely no play in my shifter ! the only problem is... I need to do at least ten of them to have the machine shop doing the work (just a turning operation, but the minimum is 100$ for any work :/ )
But before, I have to test it and check if it worth the cost !
Ben006 is offline   Reply With Quote
