Old 10-15-2014, 01:36 PM   #17
Gelbster
One issue nobody has mentioned is the grade of vinyl used for the rear window. There are many different grades available. The marine grade usually has the highest level of uv inhibitors. That will prolong the life of the window in terms of yellowing and cracking. The other issue is thickness. Thicker is not better. Thinner is more flexible. A place that does boat upholstery & tops may be a better place to shop. And be sure to ask what brand& grade of vinyl they propose using.
