Old 10-15-2014, 10:38 AM   #1
jsceash
jsceash's Avatar
You realize the 987 air box probably can't be installed without removing the motor. At the very least you will have to take out half the intake manifold. Next the MAF tube is significantly larger than the 986 I believe it is 90MM. Without some programing your air fuel mix will probably be off.
