Old 10-14-2014, 07:18 PM   #2
NewArt
Artist, 986S tinkerer
NewArt's Avatar
1. Car on jackstands
2. Run car until trans temp reaches 100 degrees F. using infra red temp tool
3. Remove filler plug with car running
4. Pump in ATF 1 with hooked filler tube until fluid overflows out the hole
5. Close plug and turn off car
6. Road test
7. Repeat if necessary after ATF has cooled down to 100 F.
It's a messy job. Temperature is important. You can make the filler out of a modified garden sprayer.
