				Known issues list
			Problem#1: Leaky rear washerResolution: Replace the leaky rear washer
 Workaround: None
 Problem#2: Rear Camera out of focus/ blurry
 Resolution: No resolution available yet
 Workaround: None
 Problem#3: Passenger door and hood clearance issue, paint damage
 Resolution: Take to dealer; some are able to fix it
 Workaround: None
 Problem#4: False alarms
 Workaround: Press lock button twice to disable alarm
 Problem#5: No spare tire on delivery
 Resolution: Spares are on manufacturers back-order, dealer to provide
 Workaround: Emergency repair kit with sealant, compressor etc. available
 Problem #6 : Side mirror adjusts up on reversing instead of down
 Resolution: Put vehicle in reverse, adjust mirror to desired position. Should be recalled on next use.
 Workaround: see above
 Problem #7 : B Pillar trim piece cracking
 Resolution: Dealer replacement under warranty
 Workaround: ignore?
 Problem #8 : Windshield wipers auto-sweeping on vehicle start
 Resolution: See dealer for wiper issue
 Workaround: none
 Problem #9 : Trailer control module draining battery
 Resolution: See dealer for TSB: reflash indicated.
 Workaround: Unknown.
 Problem#10 : One liner problem
 Resolution: One liner resolution if exists today via dealer or Porsche promise
 Workaround: One liner; if any workaround that fixes the problem
 This is originally posted in macanforum.com and edited by me. Hope this helps anyone that needs it.
