Old 03-31-2006, 09:47 PM   #1
MNBoxster
Hi,
It doesn't matter if you do the Brakes or the Clutch first. The Slave Cylinder has a Bleed Nipple, same as the Brake Calipers. You conect the Power Bleeder and then open the Bleed Niple on the Clutch Slave and l;et it run until there are no bubbles. But, be certain to fully depress the Clutch Pedal before opening the Bleed Nipple and hold it open with a Stick, or Ronzi's pwersonal fav - the Snowscraper. Hope this helps...
Happy Mototoring... Jim '99
