Old 09-26-2014, 09:50 AM   #2
steved0x
steved0x's Avatar
Originally Posted by velorider View Post
Was the rest of your exhaust system stock? I ask because I want to know if this bolts onto the factory PSE rear pieces or if putting these headers on means everything rearward must also change.
Go ahead.....say it: NOOB. But I would love a little more sparkle when I stick my foot into it -- without adding so much that I end up hating it on a 45 minute drive. Maybe what you have is the answer, or maybe I should go with a Cernewal approach at the rear end.
I believe this fits using the same dimensions as the stock "header" with integrated cat, with the exception if you have a tiptronic you have to slightly reroute one of the cooling lines.
If you want a little more sparkle, do you have secondary cat bypass pipes installed? They give exactly that. I do not have the item for sale in this add installed, but I do have the 2nd cat bypass pipes installed and I love it
