Old 09-24-2014, 01:04 PM   #1
epapp
epapp's Avatar
If you find the relay (probably next to the other fan relays near drivers left foot), you can just wire a switch in parallel to the ECU signal wire. This way, the ecu will control the compartment fan as normal, and if you want to turn the fan on manually, you can.
epapp is offline   Reply With Quote
