Old 09-22-2014, 02:43 PM   #5
Listerofsmeg
Thanks for the replies.
Gelbster, thanks for the headsup, ive build a good few engines so with any luck will be able to spot on inspection if there is serious damage worth scrapping. Fingers crossed there isnt.
Seningen, thanks i will look up how to swap that out. Hopefully the bottom (middle) end will look ok, will try and get a compression tester in there before i remove the motor as that may save a lot of time if it is sound.
Any ideas on the other issues welcome
Listerofsmeg is offline   Reply With Quote
