Old 09-06-2014, 08:27 AM   #30
BYprodriver
BYprodriver's Avatar
Yes just a couple O-ring type gaskets for crankcase halves. Did you get a full rebuild gasket set? There are many O-rings required, Those long bolts have O-rings, before you install the heads, install those 3 long bolts finger tight. After you torque the heads, then torque the 3 long bolts.
