Old 09-06-2014, 05:51 AM   #2
jsceash
jsceash's Avatar
When you turn on your key does the air pump start. With the engine hot does your fan start blowing. Those are 2 things I know are right in that area. Other things right under intake is a Knock sensor. A vacuum switch is just beside the knock sensor. Oil pressure switch is on the head valve cover right there. Other than the fan I think every other one of those would cause a engine fault on the dash.
