Old 09-02-2014, 11:05 AM   #1
jsceash
jsceash's Avatar
As noted before make sure its toasted first. Make sure the doner car is the same year and engine / transmission type to reduce possible issues.
You will need a key fab from the doner car the immobilizer and ECM. The ignition switch is up to you but most likely not needed. You would probably be able to get the car running. to get to a garage
The problem
1. odometer will show the mileage of doner car
2. radio will probably not work
3. option of dash and onboard features may need turned on or off.
4. ABS errors
Eventually you will need these corrected, a copy of purchase receipts and old units so don't just toss them if the car runs.
