Thread: Engine Stalling
Old 08-26-2014, 11:57 AM   #2
seningen
seningen's Avatar
Originally Posted by rock88hard View Post
Would it rule out water in the gas if I let it run to empty and then completely fill it up?
The top does have some leaks from cracked plastic window and the clamshell not fitting tight. Also, I did have to leave it out in the rain a few days before the problem started.
Check under your drivers seat to make sure the Immobilizer is not getting corroded.
Not sure how that might cause a stalling issue -- but the immob sits in the lowest
point in the chassis and is a magnet for rain water.
If this get's bad enough -- the car will not start, the repair can get pricey AND
if the Immob needs replacement -- it can only be programmed at the dealership.
In other words -- make sure you are not getting your Immob wet regardless
of your stalling problem.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
