Old 03-26-2006, 11:49 AM   #2
MNBoxster
Originally Posted by jeff740
Hi gents, just looking to solve a bit of a mystery. I have had my 2001 Boxster for a few months and on a few occaisions despite having lots of juice battery wise, when I turn the key to the position where it begins to fire up the starter there simply is nothing. After wiping the cold sweat from my brow I usually move the gear shift a couple of times and check to see if my after-market mats are pressing on the accelerator as I was once told that there cannot be anything pushing down on the gas pedal during start-up (not sure thats a buch of hocus pocus.) I havent bothered to try to start the car with the pedal depressed since I still have the car in storage to see if that is the truth. I usually depress the clutch on start-up out of habit but im pretty sure the fail to start situation has happened even while doing that.
If anyone could pinpoint what start-up safety feautures the car has so that I can eliminate going through this embaressing ritual when im showing my car to friends.
Thanks.
Jeff.
Hi,
There is a Starter Lockout Switch on the Clutch, meaning that the Clutch MUST be fully depressed in order for the Starter to energize. You must make sure to FULLY depress the Clutch in order for this switch to work. Note that these do fail sometimes, not notoriously, but they do. Also, the ignition switch in the Boxster isn't the most robust component and you might also be having issues with it.
You should never depress the gas on any fuel injected Car to start it. Not that it'll blow up, but it's just not designed to start in that manner. You should turn the key to the Run position (to get the Fuel system pressurized and the Fuel Pump going) and then simply turn the key. Let the Starter run no longer than say 10 sec. If the Car fails to start, wait a minute and try again (this is to protect the Starter from burning out). Hope this helps...
Happy Motoring!... Jim'99
