Old 03-25-2006, 02:39 PM   #4
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by insatiable
Have you driven a Box with 18's? If not I suggest you do because the ride is VERY MUCH firmer than your 16's
I have just changed back to 6 & 7 x 16 from 7.5 & 9 x 18 because I now drive a lot on rougher sealed roads and found the 18's were trying to shake the car apart not to mention the degraded steering at higher speed.
The 16 dramatically improved everything and in fact unless you are driving " in extremis" I doubt you will detect much difference in roadhandling.
I will keep the 18's for when I sell the car.
Cheers,
Glenn
I think this all comes down to what you are going for in your Boxster. If you are going the best suspension then the 18 inch option is the way to go hands down. If handling isn't a concern for you then 16 inch wheels are the best for comfort. By the way 18 inch wheel look SUPER good on a Boxster and will give you a much more aggresive looking car.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
