[QUOTE=986Jim]More overlap would reduce pressure in the combustion chamber as boost would be blown out the intake or exhaust valves depending on how you overlap the engine and where your dwell time is.
Yup. That's what I'm talking about...When we have seen VQ35 blown by sensible FI, most of the time the problem is valve timing...if you don't want cams, it can be tuned in, and should be to the limit of scavenging.
I mean surely the kit came with correct feul maps...
