Thread: Boxster Mystery
Old 08-05-2014, 05:28 AM   #2
aneal000
aneal000's Avatar
Man, i didn't even get a chance to chime in on this one. I'd call this one a battery all day long before even reading the fix. If it was dropping to below 3 volts (assuming it was reading over 12) while starting you have at least one bad cell if not more inside the battery. I would agree with the tow truck driver - the first guy on scene had no clue and a dead/bad jumper box. It's not surprising the car would start again shortly after jumping, even with a bad battery. I suspect if you let it sit overnight it would be hit or miss if it would start again. Sure signs the battery is done. Change it and you should be good to go!
aneal000 is offline   Reply With Quote
