Old 08-03-2014, 10:56 AM   #1
Bruce Wayne
Bruce Wayne's Avatar
Make sure the arm rest cubby compartment is closed / locked down securely.
Sometimes the hinge (@ the rear) breaks and stops the lid closing properly....
+1
Also the Boxster alarm system has a small contact switch located to the left side of the radio compartment that detects removal of the radio. In order to prevent the alarm from repeatedly going off, you need to connect this wire (brown / blue) to ground.
As an audiophile, i find the Becker CDR-22 fitted in mine as standard perfectly acceptable
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
