Old 08-03-2014, 06:16 AM   #1
method
GT3 top mounts with H&R coilovers
I've mounted a set of H&R monotube coilovers on my 986S, these coilovers can be used with the stock front top mount. The spring lands right into the stock, rubber-lined spring seat. It all works rather well.
Now, I'd like to get some extra camber as I track the car every now and then. I found a reasonably priced 996.343.181.9R GT3/Cup front top mounts that can be rotated for an extra degree of neg camber.
Diagram
Now to my challenge: in the GT3, these are used with a spring perch/top hat that channels the force to the monoball whereas in other 986/996's the spring has a ruber lined spring seat in the top mount. Some after market top mounts allow for re-use of the original spring seat which is not how the GT3 part is designed.
I'm assuming that I need something like this:
MODE spring perch or perhaps the original GT3 part. I don't know what the inner diameter of the spring is - original and H&R should be the same since the same spring seat can be used.
Is there someone here who has done this or could help me in finding the right part(s)?
method is offline   Reply With Quote
