Old 07-30-2014, 03:28 PM   #10
thstone
Originally Posted by ianacole View Post
What lifespan are you experiencing on the RRs? Is 6 cycles typical, or was it a hotter than normal day. It seemed that you were not expecting the behavior (at least that's what I took from your comments in the video).
I think that it was driver inexperience, not the tires!
With that being said, I have found that a new set per weekend is required for me to place in the Top 5. The tires last well beyond that but my speed starts to fall off. Yes, I am probably using new tires as a bit of a crutch.
A better driver would be able to compensate for the tires as they wear and keep times up through more of the life of the tire. I aspire to be that driver by year end!
Brad, can you weigh in here? What is the typical number of HC's that folks are seeing?
