Old 07-27-2014, 04:08 PM   #1
Manuell
Manuell's Avatar
Thank you!! I got this LED strip in a electronic supply here in Houston. I got 24 inches which is long enough, (it was like $35) actually i bend the tip 1/2 inch because it was to long and if you cut it you kill 3 LEDS. so basically i have one single led bended towards the inside.
Buying Online is the way to go . The picture i attached is exactly how mine look. The Surface LEDs are bigger than standard LED strips , the call them High Power Led strips.
This LED strips are always 12V, I just plug in mine.
Manuell is offline   Reply With Quote
