Old 07-24-2014, 07:08 AM   #45
aneal000
aneal000's Avatar
Gearing up to tackle this project Friday night. 1998 with 84k miles and it started squealing, drove it home, parked it in the garage and it started self draining. I pulled the belt and there was play in the pulley (bearing/bushing shot). I did notice that it looks like the squeal is due to the pulley rubbing a bolt on the engine.
I was bummed that Pelican was out of stock on the composite blade water pump but I found it online at another company and it should be here today. I already have the low temp thermostat. After reading some of these posts I'm curious about what antifreeze to use and the proper way to refill the system. I do not have the vacuum airlift system - can this be done without? How much antifreeze should I have on hand for this project?
aneal000 is offline   Reply With Quote
