Old 07-23-2014, 06:03 AM   #11
papasmurf
I wrap cars for a living (signshop)
and it is not something I would recommend to the first time user. I have probably wrapped well over 100 cars over the years and it still can be a challenge from time to time. I have been trying to get my employers to try out the vvivid brand vinyl as it appears to be decent quality. That being said, you know what you are getting when you purchase avery, 3m, or oracal materials. You are probably going to get some adhesion promoter (3M primer 94), a heatgun (we use propane torches), and have the car washed with an aggressive soap to get any wax and oil's off the paint before wrapping. The knifeless tape is expensive and kind of hard to use but is what you want if you are not going to put knife to paint. Frequently we would use masking tape under the edge and cut on that before peeling the vinyl back to remove the tape. There really should not be too many areas you have to cut on the body. To do things right, remove the headlights, sidemarkers, tailights, air vents, etc. The material stretches easily with heat so working in a cool location is always a plus.
Good luck....been thinking about wrapping my boxster in a green similar to signal green or a lime green color.
papasmurf is offline   Reply With Quote
