Old 07-19-2014, 02:52 PM   #1
KenT
986 headlight/DRL issue
I have Canadian 2000 Boxster S with litronic lights.
The Daytime running lights recently stopped coming on. Also, I noticed that the low-beams go off when I turn on the high beams. They do stay on when I just flash the high beams. I'm not sure if that is the proper behavior but at night the high beams do not seem right. The manual says the low beams should rise a bit when high beams are on.
I can't remember exactly what should be on when, but I believe there are supposed to be marker lights on (same spot on the turn signals) in front. The turn signals work fine but the marker lights in front never come on. The side marker lights do work fine.
Any suggestions? I have re-seated both headlight units. I assume it can't be fuses since all the lights work at some point. I did check the marker-light fuse and some others.
Thanks.
__________
Ken T
00 Boxster S
KenT is offline   Reply With Quote
