Old 07-14-2014, 07:49 PM   #1
3_Angels
3_Angels's Avatar
Originally Posted by thom4782 View Post
This is really simple.
If you use a sealed bearing, it must be lubricated internally period.
On the other hand, if you use an unsealed bearing, you remove the outer seal to allow oil to lubricate it. The LN Retrofit experience shows that splash oil from the sump is sufficient for the unsealed ceramic bearings to last well beyond 50,000 miles before considering a replacement.
Whether you add DOF or not, you do not remove the inner seal. If you do, oil will accumulate in the IMS tube.
Note that the "Eternal Fix" has no seals and has a flooded IMS. I am not saying that is good or not.
3_Angels is offline   Reply With Quote
