Old 07-14-2014, 06:48 PM   #1
ChairmanRon
Multiple cam-related fault codes
Friends, I could use some help.
I'm suddenly receiving three fault codes on my 03 986. Durametric reports this:
P0346:
Porsche fault code 113 - Phase sensor 2 (camshaft Hall-effect sensor 2)
P0335:
Porsche fault code 110 - RPM input circuit
P0021:
Porsche fault code 325 - Camshaft position with respect to crankshaft bank 2
I have already replaced the RPM (Reference) sensor, to no avail.
The running condition appears OK, although I believe there is a slight power reduction when this intermittent problem occurs. There is no problem starting or operating otherwise.
Can someone suggest the cause and solution?
Many, many thanks.
Ron
ChairmanRon is offline   Reply With Quote
