Old 07-12-2014, 05:01 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by Keith Newby View Post
I would first try bleeding the clutch hydraulic system since it sounds as if either the clutch master or slave cylinders isn't doing its job.
+1
worst case scenario, bad slave cylinder.
most likely, air/moisture in the system.
when was the last time hydraulic fluid was changed?
