Old 07-06-2014, 08:52 AM   #11
jdlmodelt
Originally Posted by Beer View Post
Finally found the Boxster for me.
1) I notice the gauge display and the radio stays on for a bit after the car is turned off. Is this normal?
2) I had trouble getting the key to turn in the ignition once. Is this a sign it needs replacing.
3) The wind break between the seats is missing. Is it worth replacing, do they work?
I'm sure I'll more.
2001 Boxster S
Regarding the ignition switch, mine does that when there is the least amount of side pressure on the steering. try putting slight pressure on your steering wheel in each direction and maintaining while you turn the key. It's load on the key barrel and consequent binding that is keeping the key from turning if its the same issue mine has.
