Old 07-03-2014, 12:58 PM   #1
rdass623
rdass623's Avatar
the car bypass pipes are just fine unwrapped. the removal alone of the secondary cats will lead to cooler trunk temps (as mentioned above). additionally you would need to dismember a body to fit it into the rear trunk, so they will not be complaining about the temperature. the only real "advantage" I can see out of wrapping the cat delete pipes is the addition of a substance which will hold road salt and moisture against the pipes, enhancing the corrosive properties of both.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
