Old 07-01-2014, 06:21 AM   #24
amitmishra4
So I did some more comprehensive tests and here are the results:
Battery Voltage with car sitting overnight: 12.2 V (seems slightly low but it is a brand new battery and the car hasn’t been taken out in over 2 weeks)
Battery Voltage when car starts up: 13.6-13.8V (Last night it was 13.6 and this morning it came up and showed 13.8 V actually)
Battery Voltage when the car has been running for a few minutes on idle: 13.6 V
Battery Voltage when headlights and blower are turned on: 13.4 V
Never went over 14V in my testing but do you think that if I drive it around a little and charge the battery more, it will? Or jut rev higher? If I had another person looking at it, it would be easier.
Interesting Observation: Not sure if this is normal, but I hear a slight hum from the front left side I suppose with the car turned off even and it goes away when I disconnect the battery. Is that normal?
I was not able to do the load test you asked for Jager because I was not sure what you really meant:
Turn the car on and hit the load button on tester with the (-)ve connected to chasis?
Or
Turn the car on and load using headlights and blower on with (-)ve connected to chasis?
Or
Leave the car off and do either of the above?
Thanks for all the support. What a great community. I hope that I can be of help to someone else in the future as well.
Amit
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
