06-28-2014, 11:41 AM
#2
Steel Single Row Bearing going in with DOF
We will be installing a SKF 6204 2RSJEM bearing for $13 (steel single row)
SKF 6204 2RSJEM Light Series Deep Groove Ball Bearing, Deep Groove Design, ABEC 1 Precision, Double Sealed, Contact, Steel Cage, C3 Clearance, 20mm Bore, 47mm OD, 14mm Width, 1470.0 pounds Static Load Capacity, 2860.00 pounds Dynamic Load Capacity: A
This bearing will be used in the DOF installation mentioned previously.
Installation tools will be here in Albuquerque w/ Roadrunner Region PCA
Reason: Spelling errors
