Thread: AutoTop DIY
Old 06-27-2014, 04:18 PM   #11
Polaris
Success!!!
I found the correct final sketch, and I updated it to include a parking brake pin on pin 4.
I'm a little weary about the parking break pin simply because it doesn't require an extra lock-out on the parking brake so it'll operate when somebody presses the button at any speed...in other words, use it at your own risk.
I updated the link to the code in the original post. Also, a side note, the link goes directly to the .ino sketch, but since there is no defined MIME for that extension, it just shows it as text. You should be able to right click on the link to download the actual .ino file directly.
There's supposedly a speed control wire that goes to the stereo, so I may investigate using that to set up a high speed lockout.
Polaris is offline   Reply With Quote
