Old 06-19-2014, 12:30 PM   #10
Urbanman
Can't find coolant leak
I have a '98 with 78k km. Replaced reservoir cap with new one. Added distilled water and or coolant several times, only to find no leaks to the ground. All I have is coolant soaked passenger side carpeting. Dry in the rear trunk (checked by pulling out all carpeting/hard floor panels). Have not yet checked all drain hoses, but the few I saw up front seem to be clear. I do not drive in the rain, and is kept in my garage.
Checked front of engine and water pump and thermostat housing, and all is dry. Will pressure test the system soon and hope to find leak that way.
Found the AC condensate drain pipe in passenger side to be intact and not contributing to the wetness of the carpeting.
Where is the coolant leak???
Urbanman is offline   Reply With Quote
