Old 06-13-2014, 07:21 PM   #10
BTfd2e93
Please post up a list of all of your new suspension parts.
If you lowered the car, you may be exceeding the limits of the stock non-adjustable toe arm. The fix might require a set of aftermarket adj toe arms to get everything properly aligned.
1 986-331-043-07-M80 2 Control Arm Link Track Arm, Rear Suspension, Left and Right,
2 987-333-059-00-M100 2 Rear Shock Absorber Mount, 2 Per Car,
4 996-341-043-06-M80 2 Control Arm Link, Front/Rear Suspension - Front Lower, Left and Right
5 996-341-053-17-M80 2 Control Arm, Front/Rear Suspension - Lower, Left or Right
6 996-343-515-05-M100 2 Front Shock Absorber Mount, Lower Rubber Bushing, 2 Per Car,
7 997-331-045-04-M80 2 Control Arm Link, Rear Suspension - Rear Lower, Left and Right,
8 997-343-018-01-M69 2 Shock Mount Flange with Bonded Rubber Bushing and Studs,
9 999-053-041-04-M34 4 Wheel Bearing
2x bilstein dampers (dont have the part number with me at the moment)
BTfd2e93 is offline   Reply With Quote
