Old 06-13-2014, 07:59 AM   #10
Xcellr8
Cut cables
I've got a 98 that has had the brake wear indicator and speed sensor cable cut on both front sides. So, those sensors plug into a connector at the hub. The connector has a cable that then runs through the fenderwell up into the cowl area. From there, I'm not sure where they go (assume a computer in the rear trunk?). The cables on this car were cut in the cowl and at the connector.
I would want the connector at the hub and as much of the cable in the cowl as you can get from each side.
Shipping would be to Decatur, IL 62526.
Let me know,
Thanks,
Joe
Xcellr8 is offline   Reply With Quote
