					Originally Posted by Jager  Had the car leaned to that side or did you pull some G's that would make the oil sitting in the intake to flow to that side of the car? I'm sure it's just the AOS. |
Yes, since you ask, just prior to the front straight is a sweeping left-hander where I was full-throttle in 3rd gear (probably pulling at least 1g) and the smoke screen hit just before turn exit when I was shifting to 4th gear at engine redline.
Are you thinking that may have forced oil that was introduced into the throttle body entirely/mostly to the passenger side intake runners?
