Thread: Maf
Old 03-13-2006, 04:50 PM   #6
MNBoxster
Originally Posted by PorscheDoc
Cleaning the maf with pressurized air is an absolute No No, that will almost always kill it for good.. I have had a little luck using CRC QD electronics cleaner, and letting it air dry. I have heard the dealers are using carb cleaner to clean them, and I have talked to a couple of guys who have been using the same thing with good results.
Hi,
I think it all depends upon the pressure you use, I mean it is subjected to a stream of Air above ambient pressure as a matter of course. My tendency would be to use the enclosed straw and hold it some distance away to avoid too high a pressure.
Also, some solvents may work while others can leave residue, or degrade the film, making it worse off than before. I'd be more prone to use an electronic cleaner than Carb cleaner though...
Happy Motoring!... Jim'99
