Old 05-27-2014, 05:57 PM   #10
tvlaan
Thanks all -
Here is the S i am considering:
If you look at the picture of the maintenance receipt you see the alternator at top, and then the RMS seal replacement and the resealing of the IMS bearing flange.
Language says "approved replaced leaking rear main and intermediate shaft seals" "...replaced leaking RMS and resealed intermediate shaft bearing flange"
Seeing as this was done less than a year ago - safe to assume i'd be OK in those areas?
tvlaan is offline   Reply With Quote
