Old 05-26-2014, 07:36 AM   #11
dbansal
Originally Posted by Ashmyster79 View Post
Finally fitted my aftermarket Pioneer stereo in place of the factory fitted setup. I managed to find a harness on eBay:
(Autoleads PC9-410 Active Full Bose Amplifier Adaptor Porsche Boxster Cayman) by a seller called rudiemods here in the UK
This fitted and worked on my Bose setup. I have had to forfeit the CD changer unit in the front trunk but now I have the Bose amp and door/shelf sub working well. So well pleased with the end result. All for £80 too
Make sure you connect up the blue and white wire from the harness in to the remote wire this fires up the Amp and all should be fine.
Wow! So you didn't have to change your amp? Have you come across an adapter for non Bose systems?
dbansal is offline   Reply With Quote
