Old 05-25-2014, 08:47 PM   #12
vthakka
The reman is only as good as the rebuild guy and the parts he uses.You would need a very good warrenty!
The other option was mentioned earlier-swap your internals into a good case. That should be much easier to find than the alternatives.
Thank you will check with my mechanic on that
vthakka is offline   Reply With Quote
