Old 05-24-2014, 08:58 PM   #10
Slate 01
You need to "fiddle" with the whole assembly. Keep your connections loose until everything is in place. Definitely NO cutting required.
Okay thanks, I tightened the flanges behind the primary cats, probably my first mistake. Tomorrow i loosen every joint up and then have at it once again. thanks for the tip, I'll let you know how it goes.
