Old 05-22-2014, 09:00 AM   #1
Dlirium
Dlirium's Avatar
Originally Posted by mgfranz View Post
I have a problem with my stock audio system, I have no high frequency sound coming from the front door speakers, only lows. If I fade or balance to either of the door speakers, audio is almost non-existent.
Does anyone know if the door speakers use separate signal feeds for highs and lows from either the head unit or the amp?
Wait, i'm confused. The door has a "woofer" in it, the dash has a mid and tweet. you should NOT get highs from the door. replacing the speakers with ones that have a tweeter is *probably* not the right answer. if you are not getting any high-frequency response, it's the dash speakers that are likely your issue...
